Drag&drop reordering of Navigation pane is not working
I opened several documents and want to change the order they appear in the tree. The features list of of navigation pane says “drag and drop reordering,” but it shows the no-no sign when I try to change the order of the documents.
Hi Kyle!
The drag’n’drop re-ordering applies to items within a document. The documents itself can also be reordered using the Move Up/Down button in the ribbon.
I hope this helps.
I was looking for up and down arrows in the context menu. I am used to seeing reorder buttons in a panel like that on its header. I now see the options on the ribbon. Thanks!
Glad I could help!
