Dear Team,
We have documents with more than 10,000 folders and many connection objects, and every folder has its own credential. We would like to put the document in lockdown mode to prevent users from viewing the passwords, while still being able to use them on command tasks, CLI applications, and PowerShell scripts. We understand that this is a security feature on your side, as anyone could create a connection and read the “EffectivePassword” in some way.
However, in our case, this would not be possible because the document is in lockdown mode and cannot be modified. Is it possible to create an extra flag that allows the use of the mentioned applications? This way, the admin could acknowledge the security issue in an extra warning pop-up and still use it as needed.
Thank you for your attention to this matter.
Moritz Wolf
