Disconnect Tasks not Running
My disconnect tasks are not running when I close an active connection or click the disconnect button. I can manually run the task against an active connection and it works fine, but not have it run automatically. Anything I should be checking?
I can’t think of anything that has changed settings wise but maybe a recent update has caused the issue?
Cheers
Hi Laurie,
indeed, I was able to reproduce that in the latest beta I’m using. Which Royal TS version you using? Do you know with which release this stopped working? Thanks!
Patrik
Using 4.3.10710.10000 - Beta
After updating to the newest release the disconnect task is now executing! Many thanks for the super quick turn around and fix!
Cheers
