Disable Pre-Authentication Banner
There might be some cases where you want to disable the Pre-Authentication Banner which is sent by the server before authentication happens. In this KB article, we will explain how to disable the Pre-Authentication Banner for Royal TS for Windows.
Royal TS for Windows:
Depending on which terminal plugin you are using, there are different steps you need to follow to disable the Pre-Authentication Banner. For Rebex-based connections, you can find the setting in the properties of the connection under “Terminal - Display Options - Advanced”:
For PuTTY-based connections, you can find the setting in the properties of the connection under “Advanced - SSH Settings - Auth”:
