Disable automatically focus active connections
Please make an Option to enable/disable automatically focus active Connections in Navigation tree like in the Windows Version.
Ad Hoc Connection are created on the end of the navigation tree. If you have some adhoc Connections and a large tree you must scroll back to the Server object before starting a new adhoc Connection with other credentials.
Thanks René
