Deploy
You can use msiexec to silently install Royal TS using the following options:
- Full UI:
msiexec /i [path-to-RoyalTSInstaller.msi] /qf - Reduced UI:
msiexec /i [path-to-RoyalTSInstaller.msi] /qr - Basic UI:
msiexec /i [path-to-RoyalTSInstaller.msi] /qb, /passive - No UI:
msiexec /i [path-to-RoyalTSInstaller.msi] /qn, /quiet
You can find the full documentation of the Msiexec.exe Command Line here:
https://www.advancedinstaller.com/user-guide/msiexec.html
Register
When you start Royal TS and enter the license information, a file code4ward.RoyalTS.Lic.V*.xml is written to %appdata%\code4ward
There are two options to deploy the license to your users:
Copy and deploy the
code4ward.RoyalTS.Lic.V*.xmlfile to the%appdata%\code4wardusing a log-on script for each user. -
Copy and deploy the
code4ward.RoyalTS.Lic.V*.xmlfile to the install directory of Royal TS (whereRTS*App.exe/RoyalTS.exeis located).
To update an existing license, please go to “Help - About - License dialog”. Then click on “Open - Reset License” and then enter your new license details. This will generate a new license file which can then be used to deploy your new license XML. Once the new license file has been deployed to %appdata%\code4ward, you can run Royal TS and check the license details by going to “Help - About - Maintenance” and clicking on check online.
Deploy Pre-Configured Settings
Default settings, autostart files and all settings you see in the Options dialog are stored in %appdata%\code4ward\code4ward.RoyalTS.UserPreferences.config file. If you want to deploy pre-configured settings, simply setup one instance of Royal TS with all the settings you need and deploy the file to your users when Royal TS is installed.
