Default PowerShell Dynamic Folder Script fails
The default JSON works as expected.
"Objects": [
      "Type": "Credential",
      "Name": "Root",
      "Username": "root",
      "Password": "!ehrfew9fe9gew7rgew@",
      "ID": "000001",
      "Path": "/Credentials"
      "Type": "Folder",
      "Name": "Connections",
      "Objects": [
          "Type": "TerminalConnection",
          "TerminalConnectionType": "SSH",
          "Name": "VM01",
          "ComputerName": "vm01",
          "CredentialID": "000001"
However, the default PowerShell script fails despite being identical in end JSON layout.
$ErrorActionPreference = "Stop"
    Objects = (
            Type = "Credential";
            Name = "Root";
            Username = "root";
            Password = "!ehrfew9fe9gew7rgew@";
            ID = "000001";
            Path = "/Credentials";
            Type = "Folder";
            Name = "Connections";
            Objects = @(
                    Type = "TerminalConnection";
                    TerminalConnectionType = "SSH";
                    Name = "VM01";
                    ComputerName = "vm01";
                    CredentialID = "000001";
ConvertTo-Json -Depth 100 |
Write-Host
The error received is as follows (provided as an image and text just in case):
An error occurred while parsing the output of a dynamic folder’s script: Unexpected character encountered while parsing value: P.Path", line 0, position 0.
Your Objects is missing the @.
Line 3: Objects = (
Should be Objects = @(
