Hi to all,
it is possible to implement a default action for double click with vcenter integration plugin. For example for me could be to open Console of virtual machine.
Hi to all,
Hi Carlo,
thank you for the feedback. The next release will allow you to configure the default action in the Plugin Settings when an instance is double-clicked.
