Hey,
is the Deep Keyboard Hook Feature missing in RTS v6 ?
Can’t find it in settings. ![]()
Hey,
in V6 we provide a way to individually configure keyboard shortcuts for each command available. There you can configure each shortcut scope to either be “local”, “deep” (which is the same as the deep keyboard hook feature) or global (which is a global hotkey).
https://docs.royalapps.com/r2021/royalts/user-interface/commands.html#-keyboard-shortcuts
Is it possible that the keyboard Shortcuts break in RDP Sessions if you have “Windows key Passthrough” enabled ?
I want to switch tabs with a shortcut. but its not working if its enabled.
Yes. RDP tends to “swallow” everything regarding keyboard input when Windows Key Passthrough is enabled. I’m afraid there’s nothing we can do to avoid this in this mode.
Is there any news on this after two years ?
Would be great if this can be fixed.
Hi Michael,
I’m sorry if my previous answer was not clear. Let me clarify again: this is not something we can fix on our end. Sorry to be the bearer of bad news.
Maybe i hoped that some crazy developer found a workaround for this ![]()
Or that micrsoft has changed something over time.
Thanks for your reply !
I doubt that MS will change the behavior for this case but we will keep an eye on it. Should it change, we will look into it again.
