CyberArk PAM login
we use PAM from CyberArkand they provide capability connect via putty with this string: vaultuser@targetuser#domainaddress@targetmachine#targetport@targetpassword@proxyaddress
source: https://docs.cyberark.com/Product-Doc/OnlineHelp/PAS/Latest/en/Content/PASIMP/PSSO-PMSP.htm#RemoteSSHCommandExecutionthroughPSMforSSH
it is working for putt plugin but not for rebex plugin.
Please allow it for rebex plugin as well.
Thank you
hello, please enable for new V6. thank you
i am receiving this issue:
it is limitation which is not need it,
Thank you
Got here because a huge RoyalTS fan and user and we are getting CyberArk…
Hi Andrew,
the best way to integrate CyberArk with Royal TS is via the Dynamic Folder feature. You can find a step-by-step guide on how to do this here:
https://github.com/itdistrict/cyberRoyal
Please let me know if you need further assistance by either replying to this thread or creating a new support ticket here:
best regards,
hi Andrew, I found this but it is not working in my environment https://github.com/itdistrict/cyberRoyal
is it working for you? Thanks, Filip
