Custom colors reset after opening options tab
I have customized some colors for a connection. For example, I’ve set normal black to #073642 (still using ‘ANSI Palette’). It works fine, I get a pleasant dark-teal background in my terminal.
However, if I open and then close Royal TS options tab (don’t need to change anything, just open Options and immediately press ‘OK’) - the colors in the open session revert to default and the background becomes pure black until I reconnect.
Thanks for reporting the issue. I was able to fix this for the next release.
