Hi
In other terminals i can move the cursor from begin to end and vice versa with ctrl + home or ctrl + end
in the Terminal Window in Royal TS this doesn’t work. Is there a way to send theses Key combinations?
Thanks in advance.
Thomas
Hi
Thanks in advance.
Thomas
Hi Thomas,
what plugin are you using? Rebex? Can you try to switch to the PuTTY plugin? Each terminal handles stuff like this differently and maybe PuTTY can handle that better.
Hi Stefan
Thanks for your answer
I used Rebex and switched to putty now. But it doesn’t work yet.
I played with the settings of the connection, but couldn’t solve the problem.
Thomas
I just tested with Rebex and PuTTY and you can simply press HOME / END (without the CTRL modifier key) to accomplish the same. HTH
