Since I’ve installed Mac OS 15 Sequoia developer beta 1 I can no longer use ctrl+enter to send an email in Outlook in a RDP session.
Hi Guy,
we looked into this and were able to reproduce the issue, however, the behavior is as intended as a new Keyboard Shortcut was introduced in macOS Sequoia (Ctrl + Return), which opens the Context menu for the currently focused UI element as shown in this video:
https://developer.apple.com/videos/play/wwdc2024/10124/?time=524
According to Apple, this is configurable, however, we were not able to locate where to configure this feature in the current build.
Perhaps this will be changed in the upcoming builds / stable release.
Thanks for looking into this!
It’ll arrive later in the keybord settings screen I suppose.
Hi Guy,
you’re welcome!
Yes, most likely the setting it will arrive at a later time.
Have a great day!
FYI: ctrl+enter is working again in developer beta 3 ![]()
Hi Guy,
thanks for testing this and letting us know!
