we use connections with KeePass file and setting “select existing credentials” is hard because I have to type it via keyboard it will be nice if it will be possible to use search string from clipboard(paste).
Thank you
Thank you
Hi Filip,
I’ve looked into it and found out that the UI control we are using doesn’t support this kind of interaction. I’m afraid the only way to do an “ad-hoc” search is by typing. Sorry to be the bearer of bad news…
