context menu key doesnt work at the navigation pane ?
can you please be more specific? We do not see any issues with the context menu in the navigation panel. Maybe you can post some screenshots and explain in detail what you are trying to achieve and how it is not working as expected. In general, issues which requires screenshots, videos or more detailed explanation of your workflow, we recommend to open a support ticket instead of posting those in a public forum:
Thanks for opening the ticket. Unfortunately I don’t have a keyboard at hand with such a key but after doing some research, I think I know which key to handle. I will implement it and kindly ask you to test it once the beta is release.
Ok, i’ll install beta when i\ll be available.
All is good.
Glad to hear the issue has been resolved. Thanks for testing!
