Connection Page Option Royal TSX
Using RDP, when I reboot and try to reconnect, it tries and then fails because the computer is still rebooting. Sometimes (not sure why I get it sometimes and sometimes it just closes) I get a page with a status dot and a connect button. If it’s green I can go ahead and reconnect, if it’s red I cannot connect. I’d like a way to bring up that page, maybe right click on the connection and choose connection page? Thanks.
Hi Paul,
I believe you are reffering to the Port Check functionality, which can be enabled via the “Royal TSX Settings > Behavior > Connections” section as shown here:
That’s it!
Paul
Hi Paul,
glad this worked for you!
