Connect with options: Powershell Remoting
It would be great if you could add powershell remoting to the ‘connect with options’ context menu for RDP connections. Just like SSH connections do with SFTP & SCP.
That way I can switch to a remote conesole for the same host & credentials without duplicating all my connections.
Hi Alex,
you should check out templates:
https://content.royalapplications.com/Help/RoyalTS/V5/index.html?tutorials_workingwithtemplates.htm
https://www.royalapps.com/go/blog-ts-templates
