Is it possible to login to the same site twice via ssh? I want two tabs for the same site. Right now once i’m connected i don’t see to be able to connect to the same site again.
Is there a setting i can change to allow this?
You can do ad hoc connections. Easiest way is to right-click the tab and select Ad hoc (Clone)
When i try to use the ad-hoc option it says
‘Could not handle private key file: Invalid password or bad data’
My private key has a password on it, but i do not save that in my connection profile. I type it each time.
When i first connect to my ssh session the login prompt shows asking for my private key password.
Ad-hoc does not prompt for a password at all. It just shows the error mentioned above.
I see. If you put the passphrase on the object, does it then work?
If i include the passphrase for my key it works fine.
I do not want to save the passphrase for my key.
I think I was able to fix the issue and will be available with the next release. In the meantime, can you try to switch to the PuTTY plugin? PuTTY prompts for the passphrase in the terminal itself, so maybe your scenario is covered in PuTTY already.
