I want to copy something from a shell script in a Rebex window to another window. In both windows I have the VI on.
Unfortunately, all lines after a comment also become comments.
Example:
# This is a comment
This is not a comment
changed by copy & paste in:
# # This is a comment
# This is not a comment
However, lines before the # are not changed. I checked all the settings. If I copy the lines to another application, everything is fine. It happens when pasting. What do you have to do to prevent this from happening again?
Hi Christian,
I just tried it and it seems to work for me.
Hey, Christian,
This isn’t a feature of RoyalTS. Rather, it’s a feature of vim. Vim is treating your pasted text as though you type it really quickly. When you type a comment in vim and hit Enter, the next line will also be formatted as a comment so you don’t need to type your own # character. It also operates this way with indentation - it tries to guess at what indentation level you want for your next line.
To disable this feature while pasting:
- Press
: to open the vim options prompt
- Type
set paste and press Enter
- Be sure to press
i to enter Insert mode in vim
- Paste your text
- Optionally, exit paste mode by running the option
set nopaste
