Cisco anyconnect command task
Can someone help me out, this works in terminal but I cannot set it up as a command task, I must be missing something??
/opt/cisco/anyconnect/bin/vpn -s connect vpn.company.org <<"EOF"
username
password
y
exit
EOF
I think the command task statement has to be a single line. Try escaping the line endings?
Side note, I’d put the un/pw into Custom Properties so they can be easily changed and stored as Protected Fields. Then reference the $CustomProperties.name$ in the command task.
thanks for the reply, it appears that I can get it launched with:
in the command task but no matter how I try to pass in the creds, it just won’t work. very odd
thanks for the reply, I can launch anyconnect with
/opt/cisco/anyconnect/bin/vpn -s connect vpn.soundtransit.org
in the command task but I cannot seem to be able to pass credentials for some reason
Hi @petedykinga
I created a script for this and I run it inside the ‘Terminal’ connection of Royal TSX.
The address is taken from the ‘Computer Name’:
The password is taken from the ‘Credentials’ section.
And the script is placed in the ‘Custom Commands’ section:
The number of the Group Name (in case you have to select a group upon connecting) is taken from ‘Custom Field 1’ under ‘Custom Fields’.
The script also asks you for a 2FA password in case you need to enter one.
The script also checks if there is already a Cisco AnyConnection VPN connection active. If true, it asks you whether you want to keep it or to disconnect.
#!/bin/zsh
# title				: ciscoVpnConnectAF 4 RoyalTSX.sh
# description		: This script will connect/disconnect VPN via Cisco AnyConnect with 2 Factor Authentication
# author			: Pascal Reutener   [email protected]   (a&f systems ag)
# date				: 2021-07-29
# version			: 1.3
# usage				: as custom command in Royal TSX
# notes				: The Number of the Group Name is taken from 'Custom Field 1' in Royal TSX
# change history
# 2020-03-19 | PRE  : initial release
#						usage: ./ciscoVpnConnectAF.sh
# 2020-03-20 | PRE  : remove storage of credentials in clear text file
#						and instead use a variable
#						cosmetic changes
# 2020-11-23 | PRE  : added groupName variable
# 2021-07-29 | PRE  : Make group name/number dynamic (taken from 'CustomField1')
# configure
var_uid=$EffectiveUsername$
var_pwd="$EffectivePassword$"
var_ciscopath="/opt/cisco/anyconnect/bin"
var_url=$URI$
# Group Name Number is taken from Royal TSX's Custom Field 1
var_groupNameNumber=$CustomField1$
connect_vpn(){	# ask for second password	echo "     Please enter your OTP (One-Time Password) [ENTER]: "	read -s var_passcode	echo "\n     Your One-Time Password is: $var_passcode \n\n"sleep 1read -r -d '' var_logininfo <<- EOM		$var_groupNameNumber		$var_uid		$var_pwd		$var_passcode		y	EOM# connect	$var_ciscopath/vpn -s <<< "$var_logininfo" connect $var_url}
disconnect_vpn(){	# disconnect	$var_ciscopath/vpn disconnect}
if /opt/cisco/anyconnect/bin/vpn status | grep Connected > /dev/null
thenecho "\n\n --> You have currently an active Cisco AnyConnect VPN connection.\n     Do you want to disconnect?\n" select yn in "Yes" "No"; do	case $yn in		Yes ) disconnect_vpn; break;;		No ) exit;;	esacdone
elseecho "\n\n --> You are currently NOT connected to $var_url"connect_vpn
fi
Use at your own risk.
I hope this helps :slight_smile:
—Best regards, Pascal
That did it, thanks for the help!!
