I have Word files and Excel files that I would like to have in the folder, is there a way to make it work?
You could create command tasks which opens the application and pass the file using the arguments. It wouldn’t be embedded but you could use that to start the application/document:
https://docs.royalapps.com/r2021/royalts/reference/tasks/command.html
Thanks that helped me
You’re welcome!
