I can’t seem to find any way to bulk assign color’s to connections in the Navigation pane.
For existing objects, you can use the bulk-edit feature to edit all connections at once. Please refer to the following links:
https://www.royalapplications.com/go/kb-ts-win-folderdashboard
https://www.royalapplications.com/go/kb-ts-win-bulkedit
For new objects, use the Application -> Default Settings folder to set up all the default values.
Yes perfect! Thank you Stefan.
Nick
