Rene
August 17, 2026, 1:46pm
1
I possibly found a bug in Beta 21 of Royal TS for Windows version 26.
When opening an RDP connection with “Connect with options” and “Prompt for credentials” activated, Royal TS v7 correctly shows the prompt with all saved credentials.
Doing the same in Beta 21, gives empty usernames and path columns.
Choosing one of those records and pressing OK, gives the following error message.
This did not happen with Beta 20 before.
Thanks for reporting this. We’ve fixed this for the next build.
Hello Rene,
Our lead-dev Stefan looked into this, and we just finished testing the latest Royal TS V26 - Beta 22 build, which fixes the issue.
Could you please test if this fixes the issue for you as well?
You can download the latest build here:
Install version
https://download.royalapps.com/royalts/royaltsinstaller_26.0.22.0_x64.msi
https://download.royalapps.com/royalts/royaltsinstaller_26.0.22.0_arm64.msi
Portable .zip version
https://download.royalapps.com/royalts/royalts_26.0.22.0_x64.zip
https://download.royalapps.com/royalts/royalts_26.0.22.0_arm64.zip
Or alternatively update via the In-App updater.
Rene
August 19, 2026, 1:51pm
4
Hello Christoph
Just downloded and testet it. I can confirm, the bug has been fixed.
Thank you very much for your effort
