Broadcast just for Tabs in Window
I have several diverging devices that i have opened at the same time in Royal tsx.
These devices and systems can be grouped like routers or internal routers and external routers or loadbalancer systems. I have opened these devices in one session in royal tsx.
It would be nice, if i group these devices to one window, that the broadcast function will only send the input to the tabs in one window e.g.
Royal TSX
|- Window 1
| |- Tab1
| |- Tab2
|- Window 2
| |- Tab3
| |- Tab4
| |- Tab5
The Broadcast function should in such a constellation be activated per Window.
Example. If i activate Broadcast in Window 1, then the input should only be broadcasted to Tab1 and Tab2 and not to Tab3,4,5. Same with an broadcast taht was activated for Window 2 that should only forward to Tab3,4,5 and not to Tab1,2.
If in both Windows the broadcast is activated, these two broadcast domains should also be separated.
I think it would be the best to give a new option “Broadcast to Tabs in Window” alongside to the current option “Broadcast Input to all Terminal Sessions”
