So I’m testing out the new V5 and so far am loving it; However, there is one little annoyance I can’t get over.
When connecting to servers it takes so much longer compared to v4.
Connection times to the same server in the same document.
ssh connection
Version 4 - about 3 seconds
Version 5 - about 6-8 seconds sometimes faster than others.
RDP connection
Version 5 - about 5 seconds
I love the new features of version 5 of having the tab brighter for the selected tab and dimmer for the unselected tabs. When using colors it makes it easy to see which server tab you are on.
Also might look to see if you have the documents load in the background without taking over the application. I load about 5-8 documents (depending on project) and when I first open RoyalTS I can’t do anything until all of the documents load as the app hangs. Not sure if it is possible but would be a great feature.
