What are the current best choices for syncing .rtsz file?
Dropbox, google drive, other?
Are there any recommendations or advice on sharing this file between systems, Mac and Win? I have encryption enabled.
Thanks.
Thanks.
Anyone?
Hi Roy,
sorry for not getting back to you.
The best choice for syncing Royal Documents is by using the Document Store included with our complimentary software, Royal Server:
https://docs.royalapps.com/r2023/royalserver/document-store-configuration/index.html
Alternatively, we also support cloud base file sync services, however, we’ve had users run into issues when using One Drive a while back, as this seems to been have caused by something preventing the merge process from being completed.
