We are required to connect via AWS SSM to our Windows Servers using the port tunneling feature as described on https://awscloudsecvirtualevent.com/workshops/module1/rdp/
I setup a task that runs the command line to make the SSM connection, however as it takes a few seconds to launch terminal and connect, as a result the RDP connection fails. Is there a way to put a pause before the RDP connect trys to connect? I did try the wait for completion, but as SSM has to stay open in the terminal window it never completes.
Daniel
Hi Daniel,
could you please create a support ticket, attaching screenshots of your (command)tasks’ / connections’ configuration, so we can have a look:
thanks & best regards,
I want to know what the solution was because i also want to apply it
Create a task with the following settings
General
Check Run in Terminal
Check No confirmation required
Command
macOS
command: osascript
Arguments: -e 'tell application "Terminal" to do script "aws ssm start-session --target i-xxxxxxxxxxxxxxxxx --document-name AWS-StartPortForwardingSession --parameters \"localPortNumber=9999,portNumber=3389\" --region us-east-1 --profile profilename"' && sleep 4
replace the xxxxxxxxxxxxxxxxx with your Ec2 target and profilename with your AWS profile you setup.
Under Connections, setup a connection and set the computer name to 12.0.0.1 and the port to the port specified in the script in this case 9999
Under Tasks, select a Connect Task and select Use and existing task and the task you just created; check the Wait for connect task completion.
Note this assumes you have SSM working already in the command line on your Mac.
