Autoscroll in Rebex Terminal
I
love Royal TS and I’m starting to use it for SSH connection also (Would like to
ditch our Secure CRT we are currently paying to switch all employees to Royal
TS.)
The
only thing we found to be annoying as Hell, is your “Auto scroll to
bottom” in terminal window.
So
when a script outputs continuous text, you can’t prevent it from scrolling down
to bottom… if you start to scroll up, as soon as a new character is sent to
screen the scroll resets to bottom.
You
need to implement a “prevent scrolling feature” either by a checkbox “Auto
Scroll” or like they do in secure crt (Which works really great). They do
not scroll automatically on new character unless the scroll is completely at
the bottom. This way, if you start to scroll with the mouse and it
automatically stop auto-scrolling.
Hope
you will implement something to fix the annoying behavior.
in advance
Hi Ian,
I have to correct my previous post. There’s actually an option in the Display Options page which may do the things you want:
https://content.royalapplications.com/Help/RoyalTS/V5/reference_terminalrebex_displayoptions.htm
Disable the “Scrollback Reset on Display Activity” checkbox and make sure you have plenty of scrollback lines configured in Advanced -> Input.
This is exactly what I needed. No more annoying behavior :slight_smile:
Thanks !
Glad to hear that works for you.
