When I connect to a SSH server with PuTTY, its window title changes according to my username, the server hostname, and the current path I’m in. Royal TS v7 currently only displays the connection name as was defined for the connection.
But Royal TS also exposes this PuTTY setting under
Properties - Advanced - Features - “Disable Remote-Controlled Window Title Change” – However it only seems to have an effect when connecting in an external window.
Royal TSX got this feature a while ago, would it be possible on Windows too? Automatic tab sync name
Hi Christoph,
the main reason why we didn’t implement it for embedded connections is that the text on the tab is then usually quite long and occupies most of the space. So from a UX perspective it doesn’t make much sense to enable this for embedded tabs. Let’s leave this discussion open and if more users also want to see this implemented, I can investigate if that’s possible.
If you are referring to the display name in the tree of your PuTTY based terminal connection, simply press F2 or open the properties to rename the display name.
@information When you add a terminal connection for an SSH connection, you can use either a PuTTY or Rebex based connection. I mention PuTTY in the Idea title because that’s what I use, but I guess it could be useful for other terminal programs too.
I figured out what these question-answer bots above are doing: They include huge amounts of invisible links to spam sites, you can see it in this page’s source code.
Hi Christoph,
thanks a lot for bringing this to our attention. I’ve removed the Spam-posts.
This has been implemented and will ship with the next release. Stay tuned…
Hi everyone!
The next release will behave slightly different regarding the requested feature:
Since the Disable remote window title changes is disabled by default, all users got the new behavior by default - that’s not good
A similar feature already exists in the Rebex based terminal
In order to streamline the behavior and configuration we slightly changed the configuration so that everyone who wants that feature to be enabled has to opt-in
The next release will have the following setting in the PuTTY connection’s Display Options page: Show Window Title
If this option is enabled, the tab caption will be updated to whatever the PuTTY connection’s window title reflects. Similar to the Rebex based connection, the tab caption will include both, the connection’s name AND the window title.
If you don’t see the tab caption updated, ensure the “Disable remote window title changes” in the Advanced settings page is not checked.
When I use PuTTY to connect to an SSH server, the window title automatically updates to show details like my username, the server’s hostname, and the current working directory. In contrast, Royal TS v7 shows only the connection name that was originally configured, regardless of the session details.
That said, Royal TS does provide access to PuTTY’s option to allow remote systems to change the window title. You can find this setting under:
Properties → Advanced → Features → “Disable Remote-Controlled Window Title Change”
However, this setting appears to only work when the SSH session is launched in an external window, not within the embedded tab.
See post above: enable Show Window Title
