Autofill for Webpages with Secure Gateway
Autofill does not see the fields to use when using a Secure Gateway.
Don’t know if its possible to do that.
So buildup the Secure Gateway connection so that RoyalTSX can fetch the jQuery details. After that close the connection and temp. save the values so that they can be used.
Quote form forum:
I know that one thanks :wink: Just wanting to let you know, that its not working before the tunnel indeed. Maybe you can get it to work to temporally build the tunnel to fetch the jQuery selectors.
Hello, I would love to see this working, too.
