Annoying license popup
Hi, how can I disable this annoying popup on every single startup?
Always have to click “no”.
Atm I don’t need/want/have any license.
To help google index, here is some OCR:
“The license key was issued for an older version of Royal TS. A new license key is required to unlock this version of Royal TS.
If you have active software maintenance, you are entitled to receive a free license key for this version of Royal TS. You can check your maintenance status at https://my.royalapps.com.
Do you want to open the web site now?”
Do you have a license applied? The screenshot unfortunately doesn’t show the content behind the message box. If no license is applied, you shouldn’t get this message. Also, can you post the exact Royal TS version you are using?
Behind the message box there is personal data (Name and old, now invalid license key)
Its the most recent version (7.4.50331)
Upon clicking yes or no, the license information with the invalid key closes.
Re-opening this dialog via the toolbar shows empty input fields, so I cannot remove the old license:
Can you go to %appdata%\code4ward and look for any *.Lic*.xml files? If so, delete them and restart the app.
Thanks a lot, that worked
I hope this topic is also helpful for future googlers
Or add a button to delete old licenses
Thanks for confirming the workaround. I will see what we can do better here. Deleting the older license files would basically remove the license for older app versions thus running into issues when starting the older version again.
