Allow Objects to Be Disabled
I would like to be able to check a “Disable” box on individual items as well as folder objects to disable everything within the folder. Often, I am interacting with duplicate environments and would like the ability to disable objects from environments I am not explicitly working with. Think Dev\QA\Prod. We have machines and accounts with similar names and there have been mixups in the past by users remoting and making changes to the wrong environment. Allowing the ability to selectively enable/disable certain objects would help prevent mishaps as well as allow for decluttering the interface.
