Added realvnc and radmin viewer desktop options
Many companies around me use radmin remote and realvnc remote. Can the corresponding viewers be added to royal ts?
Unfortunately that’s not possible on a technical level because those vendors do not provide an SDK to integrate a viewer or actively prevent using and embedding their window through re-parenting and provide proper CLI support for that (like PuTTY, for example). We actually talked to a lot of vendors multiple times but there’s no interest on the vendor’s side to make that happen.
Sorry for the bad news.
I remember playing with a software called remote desktop manager last year. This software can call radmin. It can call the app to open the corresponding IP, but it cannot enter the account password. However, if this is possible, I will be very happy.
Remote Desktop Manager - Devolutions
You can do this already in Royal TS using the External Application connection type. You can start whatever you want from there:
https://www.royalapps.com/go/help-ts-win-v7-ref-externalapp
You can create a template and execute the radmin call based on other connections as well with the Connect using Template feature:
https://docs.royalapps.com/r2023/royalts/tutorials/working-with-templates.html
