Add SPICE protocol for qemu/kvm virtual machines
Add support for virtual machines hosted on qemu/kvm hosts using the SPICE protocol.
Thanks for the feedback. I did a quick google and couldn’t find any information about this. Do you have further links and maybe even implementations for that protocol?
Also, on Windows, you could probably leverage the External Application connection type to integrate an external tool which supports this protocol:
https://www.royalapps.com/go/help-ts-win-v7-ref-externalapp
Hi Stephan,
https://www.spice-space.org/index.html
I hope this helps.
Thanks for the link! As far as I can see there’s no “managed” (dotnet) implementation of the client / protocol available. In this case I’m afraid that the external app connection type might be the only feasible solution at the moment. Did you try to integrate it using the external app connection?
Sorry for the lack of replies,
I will try the external app option.
