Add a Loop instruction to Key Sequence Task
the Key Sequencer is a masterpiece feature, however, it will be awesome if you can add a Loop instruction, so repetitive commands can be made easily,
You already have Sleep (Wait) instruction, so adding a loop will make it a solid feature!
check the screenshot for the suggestion
please to note this one will really take RoyalTS to next level especially for large organisations, looking forward for your great efforts as usual !
