Hello, i have a next question. Or maybe this topic need create in “Problems” but i create here)
If i want use fast (Ad Hoc) terminal connect, ad hoc not use my default ssh port settings. What i mean, i have configured default setting for my new connections with terminal, if i create new connection (tap to folder -> add -> terminal) my default settings from (Application -> Default Settings -> Terminal) worked with custom port for server, and my credentials (user and ssh key) its worked (automatically changed). But if i use ad hoc, i paste server ip address in field, tap on arrow and select terminal, my connection are broken because ad hoc try use 22 port, but, we have 1 server on port 22, i try connect here, and ad hoc use my credentials and connected me. Why ad hoc can use credentials but cant use custom port from default-custom settings?)
