It would be nice if you could ‘pin’ a connection tab in the window, so you can have connections you use often always connected and in the same location.
I’d like to see this in Windows as well. Linked to idea “Sticky tabs?”
Suggestions for pinning a tab. Options similar to:
to SQL Server Management Studio (Figure 1), where pins can be on a
separate row; -
and Visual Studio Code (Figure 2), where you can pinned tabs can be
sized (width wise) – to be an icon (compact), or (shrink) fixed size and
shorter. The “shrink” option would be really beneficial.
Figure1
Figure2
