As a system administrator
there are numerous occasions when I need to have several tabs open on
the same server simultaneously (htop, iotop, rsyncs, df, … etc).
Currently
I duplicate the connection as many times as it is necessary and then
delete (for cleaning), it would be much more comfortable if there was
the option to generate a new tab on the site or even generate a new
double click how most managers this type.
I
would appreciate, if possible, if it could be implemented for future
versions as it is now a bit tedious and still manages certain
connections with my previous software manager.
Thanks greetings.
