Dear Royal Apps community,
I’m using 1Password integration and while I can browse vaults through Royal TS 7, I can’t find any option to select password from the vault / automatically use it based on host name when I RDP to Windows Server. Do you know if this functionality even exist or integration is only about having 1Password vaults visible (without being able to read password) in Royal TS 7? Considering this documentation, it should work the way I described, but it does not for me - when I connect to server I’m asked by standard Windows Credential Prompt to provide credentials:
https://www.royalapps.com/blog/dynamic-folder-integration-for-1password
“Bear in mind that the script creates Dynamic Credentials instead of regular credentials. Thus, usernames and passwords can not be viewed, nor edited. These values will be resolved when the credential is assigned to a connection and the connection is being established.”
Maybe I missed some setting to configure?
Are the dynamic credentials showing up in the dynamic folder? If so, you can simply assign these credentials (directly or name) to your connections. When assigned, you should be able to connect to your connection(s) using the creds of your dynamic folder.
Does this help?
thank you for quick reply. I didn’t realize there is option to assign credentials on connection level (I was looking into credentials mapping from dynamic folder view). After assigning credentials manually it works well, thank you for guidance.
Last question I’d have - is there any option to force ‘clear’ logon while credentials are set for connection, so I can type other credentials than saved ones? Disabling Automatic Logon causes to use user name only from 1Password Dynamic Folder.
Best Regards
Mateusz
Glad I could help!
When you right-click a connection you can use the Connect with Options method and select Prompt for Credential to temporarily get asked to provide credentials.
thank you it works. My mistake I didn’t find it here. Application is really big and powerful, definitely going to enjoy learning it.
Have a good week!
Best Regards
Mateusz
You’re very welcome! I know the app can make you feel overwhelmed at times. If you have any further questions or issues, don’t hesitate to ask.
