When “keep disconnected tabs open” feature is enabled, it would be handy to “click” the Connect button in “disconnected” dialog by pressing [Enter] key, like with system popups where one of the button is pre-selected.
Why: if terminal is disconnected behind the screen, but you don’t see it, the cursor is blinking, you start entering a command, you raise the eyes to the screen - and you see the “This connection was remotely disconnected” dialog. Of course you want to reconnect to keep working, but with hands on the keyboard, it would be more convenient to reconnect with a key press, than a mouse click.
