Hello!
I’m having trouble finding a setting, if it even exists. I use ad-hoc VNC connections very often and each time I have to turn on scaling mode. On Royal TSX is there any way to set this to where scaling is on by default? I realize that I can create connection files and turn scaling on that way but that isn’t a good solution for my use case.
Thanks in advance!
Hi Andrew,
you can configure default settings for all connection types in the “Application” document’s “Default Settings” folder.
These settings will apply to newly created connections as well as ad hoc connections.
Hope that helps!
Felix,
That did it, thanks so much! I’m still very new with TSX and had completely forgot about the Application document!
Perfect! Glad I could help, Andrew!
Cheers,
Felix
