Variable is not working for scp connection
Hello, below settings which is working fine for ssh connection is not working for scp connection. it will be nice to have it in 26. I am using the latest beta (16).
Thank you
Filip
Hi Filip,
this is actually a bug and will be resolved in v7 and v26. Thanks for reporting the issue.
Hi Filip,
we released a new version yesterday:
Can you confirm the issue has been fixed?
hi Stefan, let me check I found something else as well
variable is not visible in dashboard for Path for Private key
thank you
yes, it is working in new version of 7. but variable looks strange in dashboard:
I’m afraid that’s a limitation of the token system. These tokens are resolved at specific times and the tree/dashboard doesn’t resolve them.
it is ok but I would expect that it will there as string with variable name.
it looks like that it tried to fill variable, but it is empty.
so it should look like as %userprofile%\.ssh\…
but I am fine with it. just wanted to report what was expected by me.
thank you
PS: looking forward for Royal Connect
Oh sorry, I was looking at the $Name$ variable - not the env var. The path in the dashboard is actually showing you the path within your document tree. This is not the path of the key file. I hope that makes sense.
i see, i have been to focus on private key. so it is not possible to add column with this option. ok
The dashboard shows “common” fields which apply to most objects. The private key file path is a very specific property which hasn’t been added to the list of available columns. If you’d like to see this implemented, please create a dedicated feature request. Thanks!
