V5 - Beta - Rebexe terminal throwing error
Hello
I am on the latest V5 beta zip version.
When I configure a connection to use rebex it throws the attached error.
Using putty connects fine.
Hi Dan,
you can either use the crash reporter to directly send us the report or you send us an email with the crash report to support(-at-)royalapplications.com
Thank you!
Apologies, downloading the latest version of BETA fixed it.
Glad to hear that! Thanks for testing the Beta!
