Hi guys.
I’m new with RoyaTS and I want to know if is possible to create a credential to be used in different webpages.
Real scenario:
I work with several web WAS consoles everyday. That consoles are exact the same but with different URL. The password for that username expires every month. So isn’t an option store one credential for every URL because I should change the password for more than 30 URL every month. Same situation if I use the Auto Fill option in every web connection.
So, there is a way to create a credential with wildcard URL and fill only the “UserID:” and “Password:” field?
The WAS consoles are the same version and same frontend GUI, so I need complete the same fields in more than 30 differents URL.
