We
take care of improving the security in our company. So we use U2F (for
example whit the Yubikey) to encrypt critical files. The Royal TS files
are currently not as save as they shuld be to fit our needs.
The
files currently only secured through the password. This leads to the
problem to use a passwort nobody could remember or to use passwords
witch are not secure enough. U2F could solve this problem by adding a
second, unique and unhackable part to unlock the files.
Could
you implement this function in future versions of Royal TS? This should
not be a huge erfort, there are good examples to get from Yubikey to
incloud in your sourcecode. We did this to some of our software too.
For
example we have tested the U2F feature in Keepass witch looks for me
kind of simular to what you did in your files to store passwords. They
have the ability to use Yubikey to unlock the passwords. Witch would be
great to see in your software too.
