Is there a possibility to add the type clipboard option directly to the toolbar instead of via key sequences and then the option.
you should be able to right-click the command and select “add to quick access toolbar” to put this on the toolbar. Does that work for you?
It is not a separate command. It is under key sequence menu. On macos I am not able to right and add it.
Thanks, Ashutosh
I see. Wasn’t aware this was a macOS question. I moved the question to the correct forum.
I just implemented this and so in the next update there’ll be a dedicated “Type Clipboard” toolbar item that you can drag into your toolbar.
Felix
Thanks a lot Felix for the quick response and solution.
