Terminal SSH Options
Is it possible to have more configuration over the Terminal options in Royal? I ask because I want to allow a newer option for StrictHostKeyChecking, but can’t seem to find a way to disable some of the current options and adding in custom options?
OpenSSH 7.6 has introduced new StrictHostKeyChecking=accept-new
I have an option to Enable SSH Host Key Mismatch Warning. When this option isi disabled (unchecked), the Terminal options set StrictHostKeyChecking=ask. When it is enabled (checked), it sets the StrictHostKeyChecking=no and UserKnownHostsFile=/dev/nulloptions.
Sample process output with Enable SSH Host Key Mismatch Warning disabled (unchecked).
jlindquist       66968   0.0  0.0 408666736   5120 s006  S+   10:52AM   0:00.01 ssh -o NoHostAuthenticationForLocalhost=yes -o StrictHostKey
Checking=ask -o ServerAliveInterval=60 [email protected] -p 22
jlindquist       66967   0.0  0.0 408497264   2496 s006  Ss+  10:52AM   0:00.01 /Users/jlindquist/Library/Application Support/Royal TSX/Plugins/Installed/7c84a650-9896-11e1-a8b0-0800200c9a66.plugin/Contents/Frameworks/lmterminal -terminaltype ssh -uselmtelnet yes -sshpath ssh -telnetpath /Users/jlindquist/Library/Application Support/Royal TSX/Plugins/Installed/7c84a650-9896-11e1-a8b0-0800200c9a66.plugin/Contents/Frameworks/lmtelnet -screenpath screen -hostname server.example.com -port 22 -username jlindquist -sshadditionalargs -o NoHostAuthenticationForLocalhost=yes -o StrictHostKeyChecking=ask -o ServerAliveInterval=60
Sample process output with Enable SSH Host Key Mismatch Warning enabled (checked).
Ideally, I would love to have more flexibility when possible to
remove or add options in order to customize the Terminal sessions such as maintaining a known hosts file and warning on host key mismatches, and auto accepting new keys if possible.
Thanks for your time!
JP
