Tasks per connection
Provide the possibility to specify tasks per connection and not have only as global tasks, to avoid having a list of unnecessary tasks when call the tasks under specific connection.
From an architectural view, this is not possible. I suggest you put those tasks in the same folder or a subfolder of the connection if you want to use it for just those connections.
Thanks, understood! That is the workaround that I’m using…my goal was to simplify..
