I have “Track Navigation tree selection in the tab bar” enabled and “Track tab selection in Navigation tree” disabled; this mostly works the way I want, but there are a few times when tab selection changes without me wanting it to:
- when clicking a disconnected entry in the tree, tab selection always jumps to the last tab
- sometimes when an inactive tab closes, RoyalTS will switch to the Dashboard tab (this doesn’t always happen, and I’m unable to reproduce it right now, but it happens often enough to be annoying)
Currently running 26.0 Beta 24, but both problems have been happening for a while.
Thanks for reporting this. We reproduced an issue where the tab displayed after navigation tracking differs from the tab internally marked as active. Closing that hidden tab can then unexpectedly activate Dashboard or another tab.
We’ve implemented a fix to preserve the displayed tab when a background connection tab closes.
Regarding the other behavior: selecting a connection without an open tab has traditionally shown Dashboard, when available. Could you share the exact steps that cause it to jump to the last tab instead, including which tabs are open and which connection you select? That would help us investigate it separately.
Looks like the first problem happens when Dashboard tab is disabled (“Don’t create the Dashboard tab” in Options → General).
Thanks for the additional detail. We tried reproducing this with “Don’t create the Dashboard tab” enabled and the tracking options you described, but the displayed tab stayed selected when clicking a disconnected connection.
Could you share a short screen recording showing the behavior and let us know which connection types you’re using, both for the open tabs and the disconnected entry? That would help us narrow down what’s different in your setup.
OK, this is weird – I tried capturing a video of the problem, and while it did happen the first time I clicked in the tree (with a WebView2 tab active, clicking a disconnected RDP session), it didn’t happen again afterwards (and I’ve been trying it for a few minutes now, and it seems to only happen completely randomly – it does happen every now and then, but I can’t seem to find a specific sequence of triggering it; during my normal use I think it happens every time I click inside the tree, but normally I also don’t use the tree very often).
One detail that may be important is that I usually have one RDP connection (from RoyalTS) open full-screen in the primary (center) monitor, while RoyalTS itself is running on the left monitor, with every other connection being embedded.
Thanks for the additional details. We still haven’t been able to reproduce this with the information available so far, though we understand it now appears to happen intermittently.
Please keep an eye out for any other conditions or patterns that might be connected—for example, what you were doing immediately before the tab switches. If you find a sequence of steps that reproduces it, even occasionally, that would be especially helpful.
