SSH Key Pair Generator
Similar to a password generator. It’d be handy to be able to generate an SSH key pair with a click or two. The key pair should then be stored in a Credential item if desired by the user.
Options to prompt the user during generation:
  • Type (default to ed25519)
  • Passphrase
  • Comment
Just adding to this as it’s semi-related. Viewing the private key of a credential, instead of having to export it to disk, would be useful too. Security-wise, it seems more secure as the key doesn’t need to be written to disk (outside of the document).
bump, but also add an additional request.
Even if the above isn’t implemented, it would be extremely useful if it was possible to paste a private key directly into RoyalTS when creating a credential. If I want to embed a private key at the moment, I need to create a new text file, paste the key in, load it into the credential and then go and delete the text file.
THanks
